I hear trickle of water running in toilet?
Old 12-26-17, 08:23 AM
D
Received 1 Upvote on 1 Post
I have a Mansfield toilet & after flushing I can hear a trickle of water still running after the tank is full. After around one minute the trickle always (so far) stops. Does anyone have any ideas on what is going on & how to stop it from happening? Thanks & happy holidays.
Old 12-26-17, 08:38 AM
XSleeper's Avatar
Received 1,960 Upvotes on 1,757 Posts
You would need to look in the back of the tank with the lid off and look to see if the water level is spilling over the top of the pipe... or if water is still coming out of the fill valve hose... or if it is neither of those it could be the flapper.
Old 12-26-17, 02:18 PM
D
Thanks for your time XSleeper
It looks like a little water is spilling over the top edge of the pipe.
Old 12-26-17, 02:28 PM
XSleeper's Avatar
When that happens you need to adjust the float downward to lower the water level inside the tank slightly so that it doesn't spill over.
Old 12-26-17, 02:55 PM
D
I will give that a try & get back to you. Thanks
Old 12-26-17, 04:56 PM
D
Tightened the float screw a couple turns & that did the trick, thanks for your time 👍.
Old 12-26-17, 04:59 PM
XSleeper's Avatar
You're welcome... Glad you got it whipped.
