Can I put a Moen Positemp cartridge or similar in this shower valve?
Old 12-27-17, 04:07 PM
Received 1 Vote on 1 Post
There are no markings on the existing shower mixer valve except the number 12269 on the left side. I have pictures available of the existing valve, if needed.
Old 12-27-17, 05:43 PM
lawrosa's Avatar
Super Moderator
Received 60 Votes on 52 Posts
We would need a pic... .....................
Old 12-27-17, 05:48 PM
Okay. I got the pics transferred and uploaded.
Thanks!
Old 12-27-17, 05:57 PM
lawrosa's Avatar
Super Moderator
Its a 1225 cartridge. You cannot put a posi temp cartridge in its place. What are your issues?
https://www.homedepot.com/p/MOEN-Sin...1225/100051867
Old 12-27-17, 06:54 PM
Issues with low flow, but before I just replaced the existing cartridge with the same thing, I wanted to be sure there wasn't an easy upgrade to a Positemp style.
Old 12-27-17, 07:44 PM
lawrosa's Avatar
Super Moderator
You can put in a new valve but you will need to cut that one out and solder new in... That is a good old style moen. No need to change it...
Its before pressure balancing..
Low pressure? Out of tub, shower, or both?
Old 12-27-17, 07:45 PM
lawrosa's Avatar
Super Moderator
Looks like tub there but may be capped.. If shower has low flow pull the head and clean the restrictor.. May be clogged...
Old 12-27-17, 07:52 PM
F
Received 35 Votes on 27 Posts
As far as I am concerned the 1225 is superior to the Positemp. You get full control of volume and temperature . Not so with the Positemp.
Old 12-28-17, 04:59 AM
P
Received 625 Votes on 578 Posts
I will take an old style faucet every time over a more modern balancing "posi temp" because it's a simpler design with fewer things to go wrong. The balancing valve can sometimes stick or become clogged with debris. Something that can't happen with older designs.
