Toilet Whistling
Old 01-14-18, 10:11 PM
Adamhoward's Avatar
Toilet Whistling
Can anyone fix my problem: My problem is my flush makes a whistling sound when I use the toilet, at the time it increases and sometimes no whistle. Whats happening? How can I fix it?
Old 01-15-18, 05:15 AM
XSleeper's Avatar
Received 722 Votes on 668 Posts
Try turning your shutoff valve toward the closed position to slow the amount of water that is being let into the toilet. There is probably a "sweet spot" that will cause it to stop making noise as you turn it closed, while not drastically affecting the time it takes to refill.
If that doesn't help you can always just replace your noisy fill valve.
Old 01-18-18, 01:35 AM
Adamhoward's Avatar
Thank you "XSleeper" for your suggestion. After changing the valve the whistle is gone.
