Cracked Bathtub
Received 0 Votes
Cracked Bathtub
Hello everyone!
The porcelain? (acrylic?) is cracking and chipping off of our clawfoot bathtub (see photos). I am not sure what has caused this. The damage is only found at the bottom of the tub. All of the repair kits that I can find online are very single scratches or chips.
Does anyone know of a bulk product that I can purchase to repair it?
Also, what's the best way to remove the broken areas and ensure it doesn't keep chipping away after the repair is done? So far I have used a putty trowel to scrape away the big parts but haven't tried using an electric sander/grinder yet to get everything.
Looks like it was poorly prepped before being refinished allowing the new finish to peel. DIY tub reglazing jobs are iffy at best. I'd recommend contacting a tub reglazer and see what he says.
Do you know the history of the tub? Is it cast iron or fiberglass?
I assume your tub was resurfaced at some point. I think your only option is a professional resurfacing. There are DIY kits but I would really, really avoid going that route. For just a bit more you can have a professional resurface your tub and have something that will last longer. Resurfacing isn't as good as a factory baked on glaze but with care you could go 10 years with it looking pretty good.
Received 0 Votes
The tub was there when we moved in. It's fibreglass. I am leaning towards getting someone professional to come do it but I always like to see the feasibility of doing it myself and also to understand what goes into it to avoid getting scammed. Do you know the name of those repair kits?
Thanks to both of you for using the term glazing. I didn't realize that's what the process was called so up until now I wasn't able to search for local companies that do this work.
We do just about everything we can ourselves in our units. One of the few jobs we hire out is reglazing tubs and sinks. I would recommend not going the DIY route here, it just tends not to work out well.
