bathtub drain stopper -- How to fix?
Old 06-29-18, 12:30 PM
Just bought a home, and I am not sure if the bathtub stopper is broken , un-installed or how to install the bathtub stopper..
Also if you can Id drain stopper Model, ( tub is sertling), I can look up videos to see how to fix it ..
pls. see attached? pics..
Thank you for reviewing my post.
Old 06-29-18, 12:48 PM
sorry about the images, I tried to link it form imagebb website , but seems that this forum does not allow external links?, so I attached files and it came out this way, I can not edit the first post
Pls. right click on the image and select "view image", give correct image
Old 06-29-18, 02:54 PM
Norm201's Avatar
Received 703 Upvotes on 625 Posts
What you have is foot lock bathtub drain.
Look at this video
https://www.google.com/search?q=step...-b-1#kpvalbx=1
Old 06-29-18, 03:08 PM
hi thanks for replying, but what I have does not seem to be same as video you linked... I have a screw on the side of the stopper..
Old 06-29-18, 03:23 PM
Norm201's Avatar
Doesn't matter. The other style is called a trip lever and that wold have a lever on the overflow chrome piece at the top of the tub.
Remove the screw that shows in you last picture. What I think you have is shown in the following site
https://www.google.com/search?client...lZkA5v3RMr4aM:
Notice the set screw on the side.
Also here https://www.google.com/search?client...JzVW9pKw6EhLM:
Old 06-29-18, 04:18 PM
Thank you! , yes it seems lift and turn, but Am I missing some part here?
The screw in the drain is too deep, and I cant imagine the side screw (2nd to last image) is going to letch on the scew on (last image) drain screw
I am not sure the indicated (yellow) part in the pic
Old 06-29-18, 05:33 PM
Norm201's Avatar
That stem appears to have fallen off your stopper part. You should be able to pull it back out. Use a grabber. It might be magnetic but I don't think so.
