Connecting 1/4 PEX to supply valve for RO system
I feel like I'm missing something. I have an new RO water filtration system. It uses 1/4 pex lines all around, including the incoming supply. I'd like to attach this to a nice little water supply valve in the basement. The trouble is, I can't find a practical way of mating a 1/4 pex line to a supply valve.
I have managed to find supply valves with a 1/4 outlet, but these have the brass collar, which I understand is not compatible with plastic. Also, there are adapters. My PO system came with a push fitting adapter for the little faucet. I tried it on a 1/4 compression male and it fit. Can you buy these magical devices somewhere?
Any ideas? I'm googled out...
I assume your filter uses 1/4" poly lines. I have never seen one that uses PEX. I was able to connect mine to my house's plumbing but it had to go through a couple fittings to make the transition. What exactly you do will depend on the fittings available. Your local big box home center might not have everything needed so going to a plumbing supplier or looking online might be helpful.
Hi Pilot Dane,
I went to a plumbing supply store today. They gave me a water supply valve with a 1/2" compression coming in and a tiny 1/4" compression going out, but with a plastic compression collar -- or whatever the thing is called that goes around the tube and is compressed by the fittings.
The plastic ferules are used with an insert, like here:
https://www.amazon.com/LASCO-17-0911.../dp/B008E5D1L8
