Shower Not getting hot enough
Old 10-17-18, 07:42 PM
B
Received 2 Upvotes on 2 Posts
I have an older Grohe shower that is no longer getting hot enough. I believe it is an issue with the temperature regulator valve because my bathroom sinks get hot. I'm not sure what this valve would look like and I don't know the model number of the faucet (from the 1990's most likely). I've looked online and can't really find anything that looks similar. Any suggestions? Thanks
Old 10-18-18, 06:04 AM
the_tow_guy's Avatar
Received 212 Upvotes on 170 Posts
Well, you'll probably have to remove the handle and trim to get a look at it. Here's some help with how they'll look when exposed:
https://www.google.com/search?client...30.PrgEbXARYwo
Old 10-18-18, 06:42 AM
B
It has a similar look to the ones from that link that have a green piece within it. Grohe 34 900 1/2 thermostatic valve. Not sure how I attach a photo to my response.
Is that green part the valve? If not what is the actual valve and how does one remove it to change?
Thanks
