Thermostatic valve removal from shower
Old 11-24-18, 05:30 AM
K
Hi I read and couldn't find answers to this problem. I am trying to replace the thermostatic valve on a valore vs-2000. The problem I'm facing is with removal of the existing valve where it's blocked by au ring with 2 tiny holes. I have never seen this and have no clue on removal of this. Any clues or help would be much appreciated.
Thanks
Old 11-24-18, 09:50 AM
Z
Received 114 Upvotes on 105 Posts
I can’t match your picture to the manual but look at page 15 Thermostatic Cartridge Cleaning. Did you remove part #4? It looks like that just spins off and then you take plug #6 out from the bottom and then pull out the cartridge with pliers. Is that dark background around the ring in your pic part #4?
https://www.costco.ca/wcsstore/Costc...322572ENFR.pdf
Old 11-25-18, 10:30 AM
K
Thanks for taking the time to post. I did do all that. The manual is missing steps for this u ring. Apparently saw the same in a gym barbell as well. It seems I'll have to remove a brass ring on front of it before I can pull the valve. No ideas how'd IIl do it without damaging it. I'll keep trying. Thx .
Old 11-25-18, 03:05 PM
K
Figured it out. These are called retaining rings and a retaining ring pliers can take them out easily.
Old 11-25-18, 03:09 PM
Z
That's good, and very good to know how you got it out.
