Removing grey (polybutylene?) connection from copper faucet connection
Old 12-27-18, 04:09 PM
T
Currently replacing our bathroom faucet. Please see the photo below. How does the gray rubber pipe disconnect from the copper pipe above it. I already unscrewed the fitting that goes over it, but it looks like this piece somehow pops off? Don't want to force it though.
Thanks in advance!
Old 12-27-18, 04:33 PM
Received 1,185 Votes on 1,097 Posts
It's just held on there with a gasket. Give it a little bend or tug and it will break loose.
Old 12-27-18, 05:26 PM
Norm201's Avatar
Received 255 Votes on 229 Posts
With age and calcium build up they may stick together. Sometimes pretty hard.
Old 12-27-18, 05:29 PM
T
Thanks. First one popped off OK with some pulling and tugging. The second one's giving me trouble, since that copper fitting is a lot older with more corrosion. Trying some WD40.
Old 12-27-18, 05:39 PM
Norm201's Avatar
That's a supply tube and should be connected to a shut off valve. Why not just cut it and replace it with a SS supply tube?
Old 12-27-18, 08:33 PM
T
So it turned out that the copper fittings on the new faucet were shorter, and didn't extend to the gray rubber fittings. I ended up removing the gray fittings and using a set of the braided stainless steel fittings that I happened to have. One is dripping a bit when I turn the faucet on, so may have to replace that one, but other than that it went OK.
