How to remove drain in stall shower
Old 02-26-19, 04:36 PM
B
I am replacing the shower base . I have enclosed picture of drain after we cut out the base. How do we remove the drain part so we can get to pipe in side the drain? The shower base is a little over 40 years old.
Old 02-26-19, 05:11 PM
Received 125 Upvotes on 110 Posts
https://www.homedepot.com/p/RIDGID-1...1405/202826782
If it's old steel drains I'd be cutting all of it out and replacing with PVC, and replacing all the supply's with PEX.
Old 02-26-19, 05:12 PM
Received 3,420 Upvotes on 3,066 Posts
Can't tell from the picture. Is that a steel drain line ?
Old 02-28-19, 05:12 PM
CasualJoe's Avatar
Received 173 Upvotes on 156 Posts
PJ, this is the drain from the other thread. In the other thread he got everything removed down to the trap.
Old 02-28-19, 05:17 PM
Thanks Joe. This is basically a closed thread...... so it will be closed and linked to the other one.
