Tighten Delta single handle kitchen faucet
Does anyone recognize the type of Delta kitchen sink single handle Faucet in the attached picture ?
It is loose and water is leaking through the base of the faucet into the cabinet under the sink. I can not find the usual U bracket and nut to tighten it. I searched google images of Delta kitchen sink faucets and youtube videos, but can not find anything that looked like this.
Any pointer is appreciated.
Last edited by PJmax; 03-09-19 at 12:58 PM. Reason: cropped/resized/enhanced pictures
Pretty hard to tell what faucet that is from the bottom. Most of the bottoms look alike.
That may have a snap on bezel on the top allowing you access to screw heads.
Unless those black caps on the thread bolts are just pushed on. In which case they get pulled off and then some tool will fit the screw.
