Wobbly faucet
Wobbly faucet
I have a wobbly tap and understand that I need to look under the sink and tighten the screw there.
the issue is that when I looked under the sink, there are just a water hose that connect to the tap and no screw!
Any idea where is the screw and what I need to tighten??
P/s. I have a photo of it but not sure how to attach here. Is it possible to attach a photo in the forum?
Right there in the center between the hoses is the nut you need to tighten. When looking up at it from the bottom turn it clockwise (righty tighty).
thanks. That did the trick! i thought that was the screw and was looking for the nut! Alas, that is the nut itself!
Another point to seek advice if you don't mind.
now that i have tighted it, the circumference around the tape seem to have a tiny gap. Do i need to seal it up with silicon or some tape? what is the silicon or tape that i need to get for this?
