Removal of p-tube help!
Old 07-25-19, 05:26 PM
N
Hello,
I am trying to remove the p-tube under my bathroom sink and it does not look like the videos I was using to assist me. There is no clearly spinnable nut like the while one show on the one side. The black side of the pictures if what I am talking about. Am I just nuts? (HA!) anyways any advice would be much appreciated.
Thank you!
Popular Reply
07-25-19, 05:33 PM
XSleeper's Avatar
XSleeper
XSleeper is offline
Received 1,531 Votes on 1,375 Posts
That's because you have glued abs or black pvc fittings. You can cut the pipe in your photo at the "M" with a hacksaw. Then glue on a slip joint adapter and use slip joint fittings all the way up to your sink. Would need a photo where it attaches to the sink to be sure.
Old 07-25-19, 05:33 PM
XSleeper's Avatar
CasualJoe, joecaption voted this post useful.
Old 07-26-19, 03:42 AM
Norm201's Avatar
Received 594 Votes on 531 Posts
This type of sink trap assembly should be banned by local codes! There is no reason to glue an appliance that is meant to be serviced. What is wrong with plumbers who do this type of thing?
Old 07-26-19, 06:24 AM
CasualJoe's Avatar
Received 164 Votes on 147 Posts
I would guess that trap wasn't installed by a plumber. It's clearly the wrong application for that type of trap.
Old 07-26-19, 03:43 PM
Norm201's Avatar
By definition that style should not be used.
trap: to catch something, then release or dispose of. Where does such a trap should be used? Prisons or institutions?
Old 07-29-19, 07:12 AM
CasualJoe's Avatar
This style trap is commonly used under bathtubs, showers, floor drains and in washer standpipes drains.
