Unusual bidet question
Old 08-11-19, 02:36 PM
L
I was wondering how one would go about having both a add on in toilet bidet that is attached via a t valve AND a hand sprayer both on the same toilet? Is this doable? What would be needed?
Old 08-11-19, 02:38 PM
Received 3,743 Upvotes on 3,358 Posts
Welcome to the forums.
There is one common line and valve feeding the toilet.
You may have to add a tee or two so you can add a valve for the bidet and a valve for the hand sprayer.
Old 08-11-19, 04:43 PM
P
Received 2,008 Upvotes on 1,800 Posts
I don't think you want to add a remote sprayer to a toilet bidet. Dedicated bidet that have sprayers have a very large bowl to catch the water. Toilet bidet get installed on a elongated bowl toilet and have a round bowl size opening. There just isn't much room to be spraying water around with a hose sprayer.
The next big problem is temperature. Bidet seats have built in water heaters. If you tie into the toilet water line for a sprayer it will be cold water. Not the most welcome in winter.
