stand up shower on/off hot/cold handle
Old 09-15-19, 04:20 PM
H
Prepping to tile a shower. I have found shower arm and head, but no control handle. All I see is very expensive valve kits that seem meant for a tub shower combo. Mine is stand up shower, no tub. Is there another name for this that I should use to search?
Old 09-15-19, 05:19 PM
Received 1,194 Votes on 1,105 Posts
So you have what is called a shower stall. You can get a basic one handle faucet. You don't need a tub diverter. The valve gets mounted inside the wall. Hot and cold water get attached to the side and a pipe goes up to the arm.
The link is just one of many available products. You can buy just the valve assembly if you already have the arm and shower head. The valves by themselves start around $65..... Moen shower valve
Holly Banks voted this post useful.
Old 09-16-19, 08:21 AM
N
Received 18 Votes on 16 Posts
Most shower/tub faucet kits have a plug to block off the tub spout for shower only functionality. Simply install the plug as per the instructions provided and toss out the tub filler spout.
H
Thank you!! I appreciate your help!
