Loose Shower Faucet Fixtures and Divertor that fell out
So the diverter fell out of our guest shower a while ago and I am just getting to dealing with it.
The concern I have right now is that my fixtures seem awfully loose and was wondering how I fix it. Below is a link to the video showing how loose they are:
https://youtu.be/zKZ2tiwvWaA
As for the Diverter....will I probably have to get a new faucet?
Thanks for any suggestions!!
Take the two screws out of the faucet trimplate to see behind it. The valve may be able to be refastened.
The spout is a bit harder to refasten. It should have a drop ear fitting on it that is attached to the framing with two screws. Sometimes nails are used. Sometimes only one screw is used.
Do you have a shower head too ? Is it loose ?
Where is the diverted that you are talking about?
Is it just part of the spout?
Can you get at the back of the showers plumbing?
Here's a picture of the diverter that fell out.
The loose diverter is not related to all the loose plumbing. The diverter is integral to the spout.
Look under the spout for a setscrew holding it on.
So yeah the diverter and the loose fixtures we're always two separate issues, but I think I am an idiot. So I just rotated the faucet to the right a few times and it tightened up to the stall wall. Still here is a video and and picture when I took the plate off. Does all this look normal? It doesn't look like the pipe is attached to the wall.
Yes.... it's fastened...... just not well fastened. There is a fitting in there like the picture I posted. Sometimes they use nails to hold it in place...... sometimes one screw. This is a very common problem usually caused by an uncaring or sloppy installer.
Is it worth trying to fix now that I was able to remove the excess play on the faucet? It seems lik it might be a pain to get through that black plastic plate thing around the shower handle
