Shower Lever Handle Question
Old 01-05-20, 10:39 AM
B
I replaced a knob handle with a lever handle on a Delta shower, but due to the knob being "deeper" than the lever, there is this white part sticking out. What should I do here? Is it as simple as getting a chrome piece to cover the white space, or does something need to be removed?
Thanks!
Old 01-05-20, 11:24 AM
CasualJoe's Avatar
Received 173 Upvotes on 156 Posts
It appears that isn't the correct lever handle for that Delta faucet, is that what Delta told you to buy? Did Delta sell you that thing? I believe I'd call them back and return it.
Old 01-05-20, 11:31 AM
Received 3,419 Upvotes on 3,065 Posts
That looks like the handle for a Delta ball type faucet.
Old 01-05-20, 12:53 PM
Received 258 Upvotes on 231 Posts
Was this a knob to handle kit or just a handle that you thought would fit?
Old 01-05-20, 02:00 PM
Norm201's Avatar
Received 668 Upvotes on 591 Posts
It's the wrong handle for the faucet set. The only solution is a makeshift method. If you can find a chrome tube of the right diameter you can cut it to fit. Check out sink tail pieces both 1 1/4 and 1 1/2 size.
