Kitchen Faucet Makes Clunking Noise
Old 01-16-20, 07:42 AM
T
Hi Everyone,
Over the past few months, our kitchen faucet will make a clunking noise when you turn it on. It seems to happen when you haven't used it in a while, but stops doing it once you have opened the tap once.
I want to say that we've also experienced an occasional air in the water lines as well, so i don't know if that is related. We live in Florida, so all of the water lines are below slab. There doesn't seem to be any leaks that i have detected.
Any ideas would be greatly appreciated.
Thanks,
Steve
Old 01-16-20, 09:34 AM
P
Received 1,561 Votes on 1,404 Posts
Have you looked underneath for flexible connection lines or a sprayer hose moving when you turn the water on?
Old 01-16-20, 09:35 AM
T
No i have not, but i certainly can.
Old 01-16-20, 07:11 PM
Received 125 Votes on 110 Posts
I'd also check the incoming water pressure.
A simple, cheap valve like this connected to an outside faucet will let you know what it is.
There's no need for it to be above 50 PSI.
https://www.homedepot.com/p/Water-So...H100/308724108
Old 01-17-20, 04:08 AM
GregH's Avatar
Super Moderator
Received 65 Votes on 60 Posts
A worn faucet cartridge can cause clunking,
Try replacing them.
Old 01-17-20, 06:16 AM
T
Well, the cold water supply line did move a bit when we turned the water on this morning. I supposed it could also be the cartridge. Our water does a good job of clogging the shower heads after a while.
