Inline under sink water filter ??? Are they worth it
Old 01-20-23, 12:29 PM
W
Received 1 Upvote on 1 Post
Do filters like this do anything/help
AQUACREST 5KDC Inline Water Filter for Under Sink, Refrigerator, Ice Maker, 5K Gallons Ultra High Capacity, Stainless Steel Hose Direct Connect Fittings, 0.5 Micron, Reduce Chlorine, Bad Taste, Odor https://a.co/d/1LibkqI
Old 01-20-23, 01:37 PM
P
Received 2,327 Upvotes on 2,069 Posts
If you were trying to link to the filter you need to select the text you want to make into the link. Then click on the horizontal chain icon. Then enter the web address of the product (it's easiest to cut and paste).
Whether or not a filter will help depends on the quality of your water. If you are on a well and have nice clear water it probably won't do much. If you have some turbidity or sediment in your water it should catch most of it. And, if you have city water it will remove chlorine/chloramine if the filter contains activated charcoal.
Old 01-24-23, 02:10 PM
Received 59 Upvotes on 51 Posts
That filter looks pretty small to filter 100% of your kitchen's cold water for a year as claimed. Does it do "anything"? It probably does. But you don't need to filter water used to wash dishes, that's just a waste of filtration.
If you are fortunate enough to have an unused hole in your sink, you'll get more life out of any filter by sending the filtered water to a separate drinking water faucet.
Old 01-24-23, 02:25 PM
CasualJoe's Avatar
Received 192 Upvotes on 172 Posts
What are you wanting to filter out of your water? I have a whole house filter, but just filter sediment. As a result, I haven't had to clean sediment from a faucet strainer in over 20 years. I am blessed with pretty good water here, but some of the really old cast iron mains add sediment to the water stream especially after a long cold winter when water mains seem to break so frequently.
