Toilet flange is inside the floor.
Old 04-17-23, 11:04 AM
T
Toilet Flange is inside the floor.
From what I see people install it and it sometime come out out the floor.
I am scared of not having a good seal. What should I do?
Old 04-17-23, 11:09 AM
XSleeper's Avatar
Received 1,844 Upvotes on 1,659 Posts
You will have to clean the top off good and then glue a flange extension on top to bring it up to the floor level. There are also push on flanges that go down into the pipe, that would ensure a better seal, but they reduce the pipe diameter.
Old 04-19-23, 03:25 PM
T
With what can I fill the sides with?
Old 04-19-23, 03:39 PM
XSleeper's Avatar
I have no idea what you're asking.
Old 04-19-23, 04:43 PM
Received 3,750 Upvotes on 3,362 Posts
I agree with the glue on flange extender.
Everything needs to be cleaned completely.
Make sure your toilet bolts are in before gluing the plate on.
Hard to tell what the sub floor is made off but the flange extender needs to be screwed down.
If you are working over concrete you could fill in around the flange with thinset.
Flange extension video
