Jacuzzi Tub Button Repair
Old 04-27-23, 07:22 AM
Received 41 Upvotes on 38 Posts
The air control button on my jacuzzi tub is not working and I'm hoping someone can assist. Logical option is to replace the button, but I can't reach the button from the access panel. I've attached two pictures; one with the button assembled, and one with it disassembled.
Hopefully you can see the black plastic plunger. It comes right out of the assembly. The plunger has a groove on it about half-way up its stem. Whatever was in the groove is not there anymore. Does anyone know what goes in the groove? an O-ring?
The aerator is stuck in high speed. I have to push to button about 20 times to get a change in speed.
Any advice on getting the button working again would be greatly appreciated.
Old 04-27-23, 07:31 AM
Marq1's Avatar
Received 1,210 Upvotes on 1,098 Posts
I would google the make and model to find replacement parts as a start!
jrsick voted this post useful.
Old 04-27-23, 10:21 AM
P
Received 2,009 Upvotes on 1,801 Posts
I would assume the groove held an O ring turning that black piece into a piston. There are numerous air switches available but I could not find individual parts for the button. Everything is sold as a assembly but you might buy one and disassemble it for parts. Or, you can try seeing if simply putting an O ring on the shaft will make it work.
