Faucet Fitting Type
Old 11-13-23, 01:34 PM
T
Received 76 Upvotes on 69 Posts
Faucet Fitting Type
I need to replace a supply line that has a 3/8 compression fitting (for the wall valve) to a 1/2 female connector (where it connects to the faucet pipe). On the old supply line the 1/2" female is not a compression fitting. Where it mates up to the faucet pipe it has a flat face to it with a rubber surround. What type of connection is that? If needed I can supply a photo of the old line (but not the faucet).
Every connection I have found has a conical rubber washer to make the connection water tight.
The old line is labeled "BOB 4458 Taiwan L5320C"
Old 11-13-23, 05:22 PM
Received 4,156 Upvotes on 3,732 Posts
The flat type connector would indicate IPS (iron pipe size).
Tapered threads flat or slightly conical washer to seal to end of pipe.
Old 11-14-23, 06:59 PM
T
Looking at it a bit closer, what I thought was a flat face is actually just the end of the hose cut off. I'm guessing this is just a cheap version of a supply line??
I'm pretty sure 1/2" IPS w/a conical gasket will work. Something like this.
https://www.supplyhouse.com/Fluidmas...sion-x-1-2-FIP
Old 11-15-23, 05:21 AM
P
Received 2,328 Upvotes on 2,070 Posts
No, it is not the hose cut off you are seeing. It is just the rubber washer inside the fitting. They are cone shaped when new but can get squished flat over time.
