Dripping Stop Check Valve of Moen shower valve
Old 12-16-23, 02:08 PM
I did my own basement a few years ago including a shower. After completing the shower/ bath plumbing I noticed a small drip on the stop check valve (one drip every few minutes). It surprisingly stopped by itself and I haven't had any issues since. My valve was a moen shower valve. Today, I did some modification to the temperature control. I shut off those valves while workng on it. When I turned them back on, they both started dripping although one appears to have stopped. Assuming this other side stops by itself too, should I be worried they are going to start back up even though I had 2-3 years where it stopped? Otherwise how do i fix this? It appears to be integral to the valve. Thank you!
Old 12-16-23, 03:16 PM
P
Received 2,229 Upvotes on 1,988 Posts
Yes, I would be concerned. Leaks rarely fix themselves but they (leaks) are good at starting on their own. Call Moen tech support and they should send you the parts for free.
