What type of fabric / upholstery is this?
Hey Guys,
I am new to this forum. I own a small sport equipment manufacturing business, and I am looking for a very specific type of material. I have no idea what it's called, or typically used for. At first glance it is a rather soft type of upholstery. I don't usually work with fabrics, so I will do my best to describe it, and I apologize in advance for most likely using the wrong terminology! Hopefully the pictures I attached will also help.
It is a short hair type upholstery. It has a ''cloth type backing'', and it looks like the way they make this stuff, is they fold the hair in half, and both ends are pocked through the backing. So the soft part, what goes on top, is those hair ends. It is quite durable, but if you glue this stuff down, and then try to peel it of, the backing comes off but the hair stays glued down.
It is definitely not your typical commercial type carpet, it's much much more soft, and you touch the ends of the hair as suppose to a loop on top like on some other material.
They are not glued down hair, they really are poked from the back of the backing, towards the top.
I hope I make some sens!! Looking at the pictures, and with that description, does anyone have an idea of what this could be? I would really appreciate your help!!
Thank you very much in advance!
Alex
Alex
It sure looks like a carpet in the pictures.
You mentioned fabric, upholstery and carpet.
What are you looking for and what will you be doing with it ?
It is called a cut pile (as opposed to a loop pile.) Used mostly to describe carpet. An on-line search for "cut pile" or "cut pile upholstery" will give definitions, examples and possible sources.
Thanks 2john02458. I ended up figuring that part out, now I'm struggling with finding a supplier that would have such a thin carpet like materiel. That stuff is about .090'' thick. Any idea where I'd fine something that thin?
