How can I hang this headboard?
Old 01-29-24, 12:41 PM
Nightfly's Avatar
We got rid of the frame, but kept the headboard. It probably is 40-50 pounds. The cavity is 3 deep. It should be easy but what is the best way to hang this behind a bed on the wall?
Old 01-29-24, 02:08 PM
Received 4,051 Upvotes on 3,634 Posts
Hard to get a feel for the final look without being there but I'd fasten a piece of wood to the wall that the headboard could hang on. You could use three nuts and bolts installed in the wood as pins to hang the headboard on. Nails with no heads could also be used as pins.
Looks like 2x4 or 2x3 would work.
