Kilz and Vinyl Floor Tiles
Hi everybody. I pulled up a cheap, crappy felt "floor" in a mudroom and there was a plywood subfloor. I want to lay down vinyl tile squares (not self-adhesive). So after cleaning off all the glue, etc. the plywood is sanded clean and smooth. Can I use Kilz as a waterproofing sealant on the plywood, prior to putting down the tile? Same question for a concrete section of this mudroom floor. Thanks so much.
Welcome to the forums!
Why do you feel the need to 'waterproof' the subfloor? While most tile adhesive will adhere to sound paint, it's formulated to go over raw wood. Properly laid vinyl tiles should give the subfloor plenty of protection from moisture provided spills and such are mopped up in a timely manner.
Hi Marksr,
Thanks for your info. The reason I asked is that everywhere I've looked online, the recommendation was to cover the plywood with a water-based urethane sealer prior to laying the vinyl tile squares. Since the water-based sealer seems to be hard to find for some reason, I decided to use Kilz, which I just happened to have. I'm testing the tile adhesion on the Kilz now, and so far it looks good.
In any event, thank you for replying.
