Vinyl tiles on particle board
Received 0 Votes
I am putting self stick vinyl tiles on particle board using the ones that use grout, with the grout i dont need to seal it with anything like shellac correct?
Vinyl - self stick or glue down - should not be put on anything other than an underlayment quality plywood and skimmed to blend all seams and nail holes. Vinyl will show any defects underneath it over time. Also, if true particleboard, it should be removed and replaced with something more appropriate for flooring. Particleboard is overall a failed experiment when it comes to flooring.
