Matching old linoleum.
Old 11-08-18, 08:44 AM
R
Received 3 Votes on 3 Posts
What does anyone think the chances of finding matching linoleum flooring that was installed 15 years ago? I have to match a small area and the remaining floor is in good shape. Thanks in advance.
Old 11-08-18, 08:54 AM
Received 22 Votes on 17 Posts
I'd say it's possible, but you'll likely have a hard time. Could you maybe cut a piece from elsewhere to make your patch then put a different type of flooring (i.e. tile) in the other area?
Old 11-08-18, 09:04 AM
Received 622 Votes on 550 Posts
I'd say it's doubtful, even if you found the same pattern/color there would likely be small differences in production tat would show. How big of an area needs repair? where in the floor?
Old 11-09-18, 10:38 AM
R
That's what I thought. Area is 6"x5' .It is at a door entrance where I repaired subfloor. No other area to remove old linoleum to match it size wise.. Thanks
Old 11-09-18, 11:24 AM
Could you maybe accent the floor with a border?
Old 11-09-18, 11:26 AM
6 inches by 5 feet, or 6 feet by 5 feet. If the former, how about just covering it with a floor mat?
Old 11-11-18, 06:54 PM
sam floor's Avatar
Received 24 Votes on 19 Posts
Patterns change constantly. If you found some that old, it would most likely be brittle.
Old 11-12-18, 10:56 PM
Received 1,155 Votes on 1,114 Posts
If this is an outside door, I like ceramic entryways.
Old 11-14-18, 09:50 AM
sam floor's Avatar
And if ceramic is too thick, there is duraceramic.
Old 11-23-18, 03:27 AM
It could be possible, have you tried a google search by image? is it an intricate pattern or just a solid colour?
