Vinyl peel and stick over ceramic tile?
Old 01-17-23, 01:20 PM
D
I figured this question has been asked, but I searched the forum and didn't see anything. I'm wondering if I can upgrade my bathroom floor by just putting down peel and stick tile over the existing ceramic floor, or do the ceramic tiles have to be removed first?
Old 01-17-23, 01:38 PM
XSleeper's Avatar
Received 1,977 Upvotes on 1,772 Posts
Tile is generally not flat enough to do that, no. The voids would cause it to fail in short order. Even sooner if water gets under it.
Old 01-17-23, 07:37 PM
Received 1,289 Upvotes on 1,227 Posts
"upgrade my bathroom floor by just putting down peel and stick tile over the existing ceramic floor"
While this will not work, it is also a downgrade.
the_tow_guy voted this post useful.
Old 01-18-23, 06:52 AM
sam floor's Avatar
Received 39 Upvotes on 33 Posts
It is possible. You would need to take out the grout and fill the gaps level with a cementious floor fill and make sure it is perfectly smooth. So, see it can be done, but probably not worth it. You are talking a lot of work for something that COULD fail anyway. What is wrong with the ceramic?
