Can you identify this void in my Concrete Floor?
Old 02-14-16, 09:58 AM
R
Question Can you identify this void in my Concrete Floor?
This square void in my concrete was found when I pulled up the carpet. It's about a 20 inch square. When I remove the wooden door/cover there is just a void to the ground beneath the concrete floor. There is no drain or piping beneath it. The wall here is concrete block and the other side is a concrete patio.
Any ideas why this void was left? Thanks.
Name:  DSCF2181 (1024x764).jpg
Old 02-14-16, 10:08 AM
XSleeper's Avatar
Received 1,948 Upvotes on 1,748 Posts
A picture of the outside, far enough back to show the entire house might give us a clue.
Old 02-14-16, 10:58 AM
R
Here are 2 pics of the outside. The first is the entire outer wall. The second is closeup opposite of the void on the inside. Thanks for the reply.
Name:  DSCF2183 (1024x764).jpg
Name:  DSCF2182 (1024x764).jpg
Old 02-14-16, 11:23 AM
XSleeper's Avatar
Only thing I can imagine is that if you would dig down in the soil you might find that there is a rough in for a toilet or shower. Unusual, since there is no vent pipe nearby... at least not that we can see.
Old 02-14-16, 12:19 PM
Received 129 Upvotes on 114 Posts
Dig down and see if it's a clean out for the sewer or shut off for the main water line.
Old 02-14-16, 12:21 PM
XSleeper's Avatar
Or maybe they thought about putting a sump pit in there, once upon a time, and never did.
Old 02-16-16, 05:54 PM
R
I dug around expecting to find drainage tile but there's nothing. And it's on the opposite side of the house from the plumbing (well and septic - I live in the country). The house is built on a slope and faces a lake so a sump wouldn't be necessary, but a drain there would have made sense.
Thanks for the replies.
