Removing mortar and mesh
Old 04-27-16, 08:52 AM
I am remodeling my bathroom, and have removed the original tile. Underneath, adhered to the plywood subfloor, is mortar, and what looks to be mesh tape, possibly glued down. I am removing as much as I can with a chisel, but a good portion is still stuck. I am goingName:  1461774978355609616205.jpg
Size:  23.4 KB to be applying Ditra over the subfloor, and I was wondering how thoroughly that mortar and mesh needs to be removed. Will leaving any, even if fairly flat, impact the tile when I place that over the Ditra? Thanks in advance for any help.Name:  1461774933363557128019.jpg
Old 04-28-16, 08:15 PM
Tape....what tape? I see plywood and the pattern left behind by the lath that was removed, right? Let's clear that up to start.
Jaz
Old 04-29-16, 04:20 AM
chandler's Avatar
Received 6 Votes on 6 Posts
I think the mesh you are seeing is the remnants of larger squares of smaller tiles held together with it. It is not an integral part of the installation separate from the tiles. I don't think it is lath.
