Grout Line (Cleaning)
Old 05-17-16, 05:07 AM
WRDIY's Avatar
Received 41 Upvotes on 39 Posts
What is the best way to clean floor grout without damaging the tiles?
Old 05-17-16, 06:29 AM
Received 1,248 Upvotes on 1,192 Posts
Bleach and a toothbrush is my first thought.
Old 05-17-16, 06:51 AM
czizzi's Avatar
The box stores have several grout cleaning products in the cleaning section. I would avoid bleach unless the grout is white as it will alter the color. I just had to re-grout an entire 3'x6' shower floor because of the use of bleach to tackle mildew.
Old 05-17-16, 06:56 AM
Ah, good point, Z. I apparently lucked out all these years with white grout
Old 05-25-16, 02:13 AM
WRDIY's Avatar
I will avoid bleach since it is not white grout. Thanks for the heads up on this.
Unfortunately, I have tried their grout cleaning products, with a steel brush, long before. None worked. I even used it with the Shark steam cleaning and that did improve a bit but not greatly.
Anyway, I am going to try OxyClean next and will update later.
