Power Grout issues (help)
Received 0 Votes
Hello,
I recently used TEC's Power Grout® Ultimate Performance Grout on my new bathroom floor (shower pan 2x2 and main floor\curb 12x12). When the grout on the main floor\curb gets wet I can literally scratch it out with my fingers or by simply rubbing it. Where did I go wrong?
By the way, this does not happen on the grout used in my shower pan (same grout used on main floor\curb). The only difference I can think of between the two is the application style and mixture. The grout used on the pan was a little more wet as to smear more easily in between the 2x2s.
Any and all advice welcome, I'm pretty screwed right now.
Thanks!
Thanks!
Power grout is a universal grout - sanded/unsanded doesn't apply. Only think I can think of is it was mixed wrong or the bag used was old. I would dig out what is bad and reapply. Make sure you wait 72 hours for cure before use and before sealing.
