Best way to fix small chip in ceramic tile
Old 08-30-16, 05:10 PM
V
what would the best way to fix this small chip in a ceramic tile
Old 08-30-16, 06:21 PM
Received 1,273 Upvotes on 1,213 Posts
Replace the tile with one without a chip in it.
Old 08-30-16, 06:49 PM
Handyone's Avatar
If you're artistic you can use a laminate repair kit to match the tile. Seamfil is the most popular.
They have color mixing charts that will get you close to what you need and then you can adjust it.
Old 08-31-16, 03:04 AM
Received 854 Upvotes on 748 Posts
I have mixed paint to match before and just touched up the chip with it. As SS stated replacement would be ideal but only if you have leftover tiles from when the floor was originally laid. The same tile bought years later may have enough differences to stand out.
Old 09-01-16, 06:11 PM
V
would there be a cheaper method ? Maybe some sort of filler and paint over ?
Old 09-02-16, 03:20 AM
How deep is the chip? ,,,,,,,,,,
Old 09-05-16, 12:59 AM
V
@marksr it's roughly about 1/8" in depth. The unit is a rental and I have no idea whether there are any left over titles that the landlord may still have. Would tile grout work equally well ?
Old 09-05-16, 02:40 AM
Since it is a rental the landlord should be kept in the loop!
Grout might do ok although it's doubtful any patch will be totally invisible.
Old 09-06-16, 08:00 AM
I said replace the tile because, IMO, this kind of thing really isn't fixable.
I agree, talk to the landlord.
Old 09-09-16, 01:00 PM
V
Would an epoxy filler work ?
Lepage epoxy filler at Canadian Tire
http://www.canadiantire.ca/en/pdp/le...-0671407p.html
Reference to using epoxy filler
https://www.reference.com/home-garde...6484bc5e619a63
Old 09-09-16, 01:32 PM
It might work but unless you are an artist and can match both the texture and colors - any patch will show.
