How to fix laminate floor?
Old 01-06-17, 11:07 AM
C
Received 5 Upvotes on 5 Posts
My laminated floor is slightly coming off. Are there ways that I can fix it?
Old 01-06-17, 11:16 AM
Received 1,248 Upvotes on 1,192 Posts
Laminate floor generally is not fixable, it gets replaced.
Old 01-06-17, 12:32 PM
Received 800 Upvotes on 703 Posts
Couldn't tell from the pic, is it delaminating or just separating from the adjoining piece?
Old 01-06-17, 02:14 PM
chandler's Avatar
Received 9 Upvotes on 8 Posts
That doesn't look like laminate, but I could be wrong.
Old 01-06-17, 02:52 PM
C
Can I just insert some wood glue underneath this thing and put some weight on it? Would wood glue work?
Old 01-07-17, 07:48 AM
C
It's delaminating but since it's close to an adjoining piece, it's both I guess.
Old 01-07-17, 08:47 AM
Sure looks more like real wood than laminate, could it be engineered wood?
If you can get glue under it and then set something heavy over it to hold it down until the glue dries.
Old 01-07-17, 09:30 AM
Handyone's Avatar
It looks like your laminate locking joints have failed. Wood glue is your best bet, like titebond II.
Be patient pushing the wood glue into the joint, you can use a toothpick and an artists brush.
After applying the glue, try to kick/nudge the boards together and tape the joint until glue dries.
If you can't kick the boards together you can try to cut out some of the locking joint with a sharp utility knife and see if that closes the joint a little.
The locking joint is hindering rather than helping and it needs removed.
Old 01-07-17, 04:34 PM
C
Thank you all for the responses. Any suggestion on how to get glue underneath this thing? I don't think tooth pick will be much help. I was thinking about a syringe with a needle....but I don't know where I can get a glue syringe so I can squeeze underneath the coming off part.
Old 01-07-17, 04:54 PM
chandler's Avatar
Insulin syringes and needles are small enough, but you may have a tough time since the glue is so thick. Worth a shot.
Old 01-07-17, 07:44 PM
sam floor's Avatar
Received 31 Upvotes on 26 Posts
At one time flooring supply stores sold syringes made just for that thick glue.
Old 01-07-17, 07:56 PM
XSleeper's Avatar
Received 1,839 Upvotes on 1,654 Posts
Your local veterinarian is a good source for those kind of syringes. Plastic tips you can cut to size like a caulking tip.
