stone tile sealer
Old 02-27-17, 07:46 PM
D
stone tile sealer
i have some of that irregular stone-like tile wall that will be exposed to water. there are slight gaps between the tile (big enough to slide a paper through, but not much bigger) that i'd like to water proof. i see some tile sealers at Lowes/Home Depot 32oz for about $50 bout not sure if it would be good enough to seal a gaps 1-2mm wide. anyone have any experience with this or recomendations on what to use? Thanks!
Old 02-28-17, 01:30 AM
Marq1's Avatar
Received 1,142 Upvotes on 1,035 Posts
The sealer itself will not seal gaps, all it does is coat the surface of the tile to seal. where is the tile that it will see water?
Old 02-28-17, 04:32 AM
Received 758 Upvotes on 663 Posts
Grout fills the gap between stones/tiles, sealer can help seal the grout. IF this is a shower or exterior wall the waterproofing starts behind the tile!
Old 02-28-17, 06:46 AM
D
What would you recommend to seal gap? I imagine caulking would be difficult with the irregular tile surface. It's an accent wall in a walk in shower
Old 02-28-17, 06:49 AM
D
Thanks market, I can grout but I can just imagine how hard it would be to grout the irregular surface and to clean up, was wondering if there was a simple transparent 'paint-on' sealer that fills gaps
Old 02-28-17, 09:31 AM
What is behind the tile wall? There should be plastic or roofing felt, then cement board. A good coat of RedGard over the cement board can be substituted for the vapor barrier behind it. This method pretty much waterproofs the wall.
Sealers work over porous surfaces but will not span gaps to seal them. If you post a pic or two we might better understand what you are dealing with - http://www.doityourself.com/forum/el...-pictures.html
