Gap between accent wall tile and drywall
Old 06-12-17, 02:44 PM
Z
Just got an accent wall tiled in a powder room. Tiling looks great; however, it made obvious how unsquare the wall is. At some places where the tile meets the wall, there is basically no gap. At other places, there is up to 1/4 inch of gap between the end of the tile and the wall. And yes, the tile is nice and straight.
Initially I was just going to caulk around the boarder and paint the same color as the wall; however, 1/4 seems too large to just caulk.
Any suggestions how to handle where the wall meets the tile?
Thank you in advance.
Old 06-12-17, 03:09 PM
XSleeper's Avatar
Received 722 Votes on 668 Posts
If the tile is straight, mask a straight line on the tile and float the wall out to meet it with joint compound. Depending on how thick it is, you may want to float it with a 6, 8, 10, or 12" knife, depending.
Sand, prime and paint... then caulk the now straight transition with matching grout caulk.
Old 06-12-17, 05:00 PM
czizzi's Avatar
Received 14 Votes on 12 Posts
Glass bead molding is a very thin piece of wood trim that would be non-obtrusive and finish off the area nicely. Stain it to match the surroundings.
Old 06-12-17, 05:42 PM
Marq1's Avatar
Received 397 Votes on 371 Posts
I'd go with your original thought, tape off the tile, caulk, paint. You're focused on the gap now but when filled and painted it will be a distant memory.
Old 06-13-17, 03:38 AM
Received 332 Votes on 295 Posts
While the other 2 fixes are better, I agree with Marq. Couldn't count the times I've caulked similar gaps and once painted nobody noticed.
