In Kentucky is underlayment required?
i plan on putting some tile flooring down on the lower side of my house. I live in a bi level. The room has carpet now I plan on ripping it out and tiling it. It’s on the lower level and under the carpet is the slab. I’m from fl so I’m not sure if I can till direct on the concrete.Any help would be awesome.
Not sure if you have to worry about moisture under tile buy I would tape a square foot of plastic sheet down and leave alone for 24 hours and see if any water is under it.
If you haven't had any moisture problems with carpet I wouldn't worry about it. Just give the slab a close inspection and grind off any bumps that might prevent the tile from sitting flat.
