Keep existing vinyl floor ?
Received 0 Votes
This is the laundry room. I want to install new ceramic tile floor. The existing surface is vinyl squares on top of concrete.
Must I remove the existing vinyl or can I get away with keeping it by using a flex-type of thinset mortar for the ceramic ?
Received 0 Votes
Yep - called my local rental company. They vibrate with an 8 inch blade. Rents for $64 / day or the weekend.
Looks like the only way to go. Otherwise, I could see the removal taking several days.
Brutal, just brutal.
If it was put down correctly, it should be difficult to remove. Test with a heat gun, you might get luck and they were those peel and stick kind of tiles. When done, check back and tell us what you find underneath as far as subfloor. May need to beef it up for tile before proceeding.
Received 0 Votes
Thanks guys...I have a good heat gun...I am going to give that a shot before renting the scraping tool.
However, right now I am now thinking the surface is a SOLID sheet of vinyl with a pattern to look like squares....SHEESH !!
Now what ?
Now what ?
If it is sheet vinyl, it will be installed over a 1/4" sheet of plywood underlayment. Both the vinyl and the underlayment need to come up for tile, then tell us some more specifics of what you find once you remove everything. Tile need a solid base for success.
