grout cure time
Old 09-22-18, 09:33 AM
Received 800 Upvotes on 703 Posts
grout cure time
I just got done grouting the new tile in my shower. The label on the unsanded grout says it can't be flooded with water for 21 days. What does that mean? I know the wall tiles won't be under water but expect water would run down them during a shower. How long do I need to wait before using the shower?
If I remember the last tub surround/shower I did [only one] I used the shower the next day although that was close to 35 yrs ago.
Old 09-22-18, 10:47 AM
Shadeladie's Avatar
Super Moderator
Received 370 Upvotes on 299 Posts
We just regrouted ours a few months back and I think we just waited a couple days. I think it said to wait 24 hours to put the sealer on and then another day after that, altho not 100% sure if we had to wait after the sealer. Anyways, the grout did fine.
Old 09-22-18, 12:42 PM
Marq1's Avatar
Received 1,210 Upvotes on 1,098 Posts
Seems excessive, concrete drive sure, grout?
Old 09-22-18, 07:14 PM
XSleeper's Avatar
Received 1,844 Upvotes on 1,659 Posts
It was premixed grout, I assume? Not the powder you mix yourself?
Old 09-22-18, 08:13 PM
czizzi's Avatar
Grout needs to cure 72 hours before sealing. Seal with a quality grout sealer. Test, if the grout darkens when moisture is applied, then you need to reseal.
Old 09-23-18, 03:53 AM
This is the grout I used - https://www.lowes.com/pd/MAPEI-10-lb...-Grout/1119247 [not premixed]
Old 09-23-18, 03:24 PM
czizzi's Avatar
Yep, 72 hours and then seal. You used the right stuff, Mapei makes excellent grouts and mortars. My go to brand for most all projects.
Old 09-23-18, 03:34 PM
XSleeper's Avatar
I think by immersion they must mean "submerged in water" like the bottom of a pool or tub would. Says in the instructions right before that its ok for residential use after 72.
Old 09-24-18, 03:35 AM
Thanks, if the instructions [or my perception of them] had been a little clearer I wouldn't have had to ask. Any preferences on which sealer to use?
Old 09-24-18, 02:51 PM
czizzi's Avatar
You won't like the price, but this is my go to sealer. Can be found at that big orange store.
https://aquamix.com.au/products/seal...ld-rapid-cure/
Old 09-24-18, 03:01 PM
You are right, don't like the price .... surely I don't need that much grout sealer ??
Old 10-01-18, 08:51 AM
G
48 hours cure time.
I've been regrouting tile for 27 years and 48 hours is ample time for grout to harden, if you use a good admix, not water.
Old 10-01-18, 10:11 AM
I had used water. I found out after the fact that there is a liquid you can mix with the grout so you don't need to seal. I waited 72 hrs for the grout to dry, sealed and waited another 72 hrs before putting the shower in service. I bought a 6 oz bottle of grout sealer at Lowes which was enough to do both the shower and the bath rm floor.
