Install tile in plywood wall
Old 11-11-18, 12:12 PM
Received 3 Upvotes on 3 Posts
Hi all,
We had new granite countertops installed and Im going to install ceramic tile for a backsplash. The walls in this place are 3/4 plywood. I understand for a plywood floor I would need backer board. Can I install the ceramic directly to the plywood wall or do I need to add backer board?
Thanks,
Jim
Old 11-11-18, 01:26 PM
Marq1's Avatar
Received 1,211 Upvotes on 1,099 Posts
Use a good latex fortified mortar (non pre mixed) and you will be fine!
Old 11-11-18, 06:55 PM
sam floor's Avatar
Received 40 Upvotes on 34 Posts
Marq1 is right. You should be OK. Be careful that the plywood doesn't suck all the moisture from the mortar. Might want to wet the plywood.
Old 11-12-18, 04:18 AM
Marq1's Avatar
I had a similar thought on this after I posted.
The comment about moisture is valid, a coat of primer might be a good precaution, it's certainly not going to cause any issues!
Old 11-12-18, 07:30 AM
Great! Thank you both.
