Doing a mud job and tiling
Old 03-19-19, 05:38 PM
B
Doing a small bath room 52X76 in. The sub floor is 1X4 about 30 -40 years old. I have read to put tar paper down and that I can use chicken wire stapled to the floor. Instead of the chicken wire I was maybe thinking of using 1/4 in cement board. I am putting Pex tubing on top of the chicken wire or cement board. What would be the minimum thickness of the mud job. Height is a problem. Should I use bags of mortar mix or some thing else.
Old 03-19-19, 06:31 PM
Tolyn Ironhand's Avatar
If height is a problem then you will not want to put PEX in the floor. It will raise the floor height by 3/4" or more. There is also new technology than a mud base. I would recomend doing more research for better options.
Old 03-20-19, 03:17 AM
Another option would be the electric grid type floor heating as it doesn't require much additional height.
Old 03-20-19, 05:33 AM
B
This is part of NYC and electric is very high and going higher all the time. Could you pint me into the direction of the newer method.
Old 03-20-19, 09:19 AM
2
Check out Quik-Trak at SupplyHouse.com.
https://www.supplyhouse.com/sh/contr...ext=quick-trak
I have used 1/2 inch panels under 1/4 inch cement board and tile for bathroom floor.
