Floor tile around a Acrylic shower pan?
Old 05-24-23, 04:18 PM
R
Should I butt or leave a gap[ when installing porcelain floor tiles around a Acrylic shower pan? I assume the pan my flex and crack the tile. If so what size gap and should it the gap be filled with silicone?
Old 05-24-23, 04:29 PM
Marq1's Avatar
Received 1,210 Upvotes on 1,098 Posts
You got it, always leave a gap where materials, and planes, exist and caulk. But don't use silicone, you want to use a siliconized latex caulk, with microban, or a tile matching caulk. Silicon caulk is old tech and will eventually fail and allow mold growth behind the caulk. Have replaced too many to mention, they are always a nasty mess!
sam floor voted this post useful.
Old 05-24-23, 04:34 PM
R
would a 1/16 gap be be ok?
Old 05-25-23, 12:29 AM
Marq1's Avatar
I'd be more inclined to leave a slightly larger gap, 1/8", since it's going to be covered with a caulk material you wont see it and the shower material will expand when exposed to hot water.
