Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Walls and Ceilings
Reload this Page >
Best tool for cutting a long channel through drywall?
Old 03-16-16, 10:35 AM
D
I'm replacing a garage door opener in a garage with very low clearance. I need a channel cut in the ceiling drywall to give it enough clearance. The existing channel from the old opener isn't wide enough, so I need to cut it wider and a little longer to accommodate.
The picture above shows part the existing channel. A section nearest the door is cut all the way through but the rest is cut only through the first layer of drywall. I'm looking for a tool that can help me cut a relatively straight (following a snap line or something) cut only through the first layer of drywall.
This is what I've found so far in my limited research: http://www.amazon.com/RotoZip-SS560V...ywords=rotozip
Any help appreciated.
Old 03-16-16, 12:45 PM
P
Received 5 Votes on 5 Posts
A sharp knife and a metal straightedge should be a simple solution.
- Peter
Old 03-16-16, 12:59 PM
Received 94 Votes on 83 Posts
Keep in mind that two layers of drywall is possibly a fire code and you would then be violating it.
Old 03-16-16, 01:14 PM
C
Received 2 Votes on 2 Posts
Have you looked into using a Quick-turn kit, which allows you to install an opener with less than normal clearance? Or for really small clearance, they make dual track systems.
Old 03-16-16, 03:09 PM
Received 79 Votes on 74 Posts
Even what's been done so far is against code.
Something was done wrong if that's the way it needs to be done.
Old 03-16-16, 03:28 PM
chandler's Avatar
Received 6 Votes on 6 Posts
Question regarded proper tool. Use a multimaster following a straight line.
Old 03-16-16, 06:03 PM
A "multi master" is an ossilating tool.
It will do the job but what your trying to do is just wrong.
Old 03-16-16, 06:47 PM
R
Received 29 Votes on 25 Posts
You might want to consider something like this instead.
8500 LiftMaster Elite Series® Wall Mount Garage Door Opener
