Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Walls and Ceilings
Reload this Page >
How do I make ceilings in two rooms level?!
Old 05-14-16, 10:16 PM
I'm planning to remove a wall that I have dividing the kitchen and the mud room to the garage. The only issue I have is that the ceilings are two different heights. How would I raise the ceiling in the mud room to match the kitchen? I've already squared away everything else by the way! 😁🤓
Old 05-14-16, 10:28 PM
P
Temporarily Suspended
Are you sure that the wall isn't load bearing? What's above those 2 rooms?
Old 05-14-16, 10:57 PM
Received 1,109 Votes on 1,029 Posts
Welcome to the forums.
Not much a way of raising a ceiling. You may have to build the ceiling down to match.
it would actually be pretty strange for those two ceilings to be different heights.
Maybe the mudroom was an addition.
Old 05-15-16, 01:28 AM
It's a single floor home, so above these rooms is the attic. And the home is only 6 years old so I'm pretty sure it's not an addition.. It is odd but I live in Florida, so nothing is off limits.. I have checked the blueprints and it's a superficial wall for sure.
Old 05-15-16, 02:06 AM
Thanks for the warm welcome by the way! First time homeowner and we just bought the house and moved in last week!
Old 05-15-16, 02:28 AM
pugsl's Avatar
Received 74 Votes on 67 Posts
First you need to find out why the ceiling is lower, pipes, wiring etc. in there. if just for decoration then if is just a matter of tearing out old and putting in new. May need some framing or just screw drywall to studs. Hard to tell without knowing what is under ceiling.
Old 05-15-16, 03:38 AM
Received 316 Votes on 280 Posts
As mentioned above it would be odd for the two ceilings to be at different heights. Do you have access to that area in the attic? That would allow you to see how it's framed and why. Is the mud room ceiling the same height as the garage ceiling?
Old 05-15-16, 03:47 AM
chandler's Avatar
Received 6 Votes on 6 Posts
To keep from having to cut into the ceiling to see what is there, I recommend spending a hundred dollars for one of these at the box store. A dime size hole will give you access to what is up there. Costs a little, but repairing holes can take time, too, so it is a trade off. Once you determine what is up there, you can make an informed decision whether it is feasible or not.
Old 05-15-16, 06:34 AM
XSleeper's Avatar
Received 667 Votes on 617 Posts
What are we talking about... a 1/2"? 4"? 12"?
Old 05-18-16, 08:05 AM
W
Received 17 Votes on 16 Posts
Ceiling Height
Does the mud room include laundry appliances?
Are the floors in the two rooms the same height?
Some photos would help us help you.
Old 05-19-16, 07:04 AM
B
Received 88 Votes on 77 Posts
If the ceiling height difference is just a few inches, attach a decorative beam to the ceiling where the wall was removed. With just a little patching and painting, your done. Only a star gazer, on a good day, will ever notice the difference.
