Removing and replacing tile walls in bath?
My dilemma: 4 ft. high section of tile covers 3 walls in small bathroom. I'd like to remove it, but I've discovered that it was installed in a thick bed of cement, back in the 50's. One wall faces exterior, and has no insulation at all, so the tiles conduct the cold really well, and it travels through the room. Would you risk trying to remove it, or just find a way to cover it somehow? Since the room is so small, re-framing isn't an option. Thanks for any suggestions.
No matter what you cover it with the wall will still be cold unless you bite the bullet and get that wall opened up, and add the needed fire blocking, air sealing, and insulation.
Little late in the year do be doing it from the outside.
Reframing? Like leaving the tile and building new walls inside of it? Wouldn't even consider something like that.
Remove the tile, address the insulation issues, install backer board and put up new tile.
Are you worried you might damage something other than the walls in the process?
There are plenty of people here that can advise on a tear-out.
If you are thinking about just ripping out the exterior wall and saving the other two tiled walls, that's not an option or wouldn't be worth it.
You're in a good situation maybe, rip it all out. It's much easier to remove a mortar bed if you're not concerned with wall damage.
Thanks to all for your input. Luckily, if I decide to do the demo, it's all inside work. Exterior is brick (which is part of the temperature problem). Sadly, I already opened up the top part of the exterior-facing wall, and tried using foam board to insulate it a bit (because there's only 1/2" of air space to work with), and it didn't help. Getting rid of that tile seems like the only option, at this point, and I'm not sure that will help much, either.
What is between the tile and the brick? should be more than 1/2" .... or am I totally misunderstanding what you have going on?
I'd consider removing the 1x3 furring strips and replacing them with 2xs. I'd then fill the cavities with foam making along with a vapor barrier before redoing the wall/tile. Making the room 3/4" smaller shouldn't be a deal breaker.
That's a good option, though it involves ripping out all the work I already did on the top portion of the ext-facing wall. It will also create a bit of a challenge where the tub's tile continues into that wall, and above the tub's tile, as well. I know it's the best approach, though. Thanks!
