Sanding spackle under redgard
Old 07-31-17, 05:19 PM
G
Hi all,
I tore down all of the walls and tile in a shower and put up new cement board. I put redgard over all of the cement board. However, in one spot along the seam between two boards where I taped, the spackle is not completely flush. I noticed it after I put the redgard up. It is raised maybe about a 1/16 or more of an inch, and about 3 inches across.
My question is:
should I leave it alone and tile over it. My concern is I will have a tile that is raised.
can I cut the redgard and sand it down and then reapply the redgard
should I just cut the piece out all together.
thanks
Gary
Old 07-31-17, 05:39 PM
As small as 1/16" is, it means a lot when it comes to tile. Cut out the section & level it.
Old 08-01-17, 04:17 AM
You said spackle ?? Neither spackling or joint compound should be used under tile in a wet area. Thinset would be the correct material.
btw - welcome to the forums Gary!
