Is this a load bearing wall ?
This house has a separated formal living room (sunken )and great room on the other side. I want to remove the wall in between. It is s single story with engineered scissor trusses. The wall is off center of the gable peak. I think the trusses are engineered for free span, but not 100% sure if this wall may be load bearing or not. Whats is the simplest way to determine if it can be removed without adding a spanning beam ?
Once the wall is out, I need to fix the elevation change in the floor. It sits on a concrete slab, and I assume I can frame joists 16" on center and deck with plywood to match the existing higher concrete, then lay all new engineered hardwood.
I appreciate any advise you may have. Thank you.
One would think that the wall is not load bearing, but there is no way to know without being there to actually look at the trusses.
