Bulging seam in drywall
Old 04-30-18, 01:26 PM
Hi there - We moved into an older(ish) house last July and hung this picture shelf shortly after. There was a heavier photo frame in front of the problem seam in the attached picture. I started noticing a bulge behind that frame not too long ago but today it seems considerably worse than it was. It's hard when I push it, as opposed to soft, and doesn't seem to have any give. I don't know if the problem is the heavy frame on the shelf, the screw and anchor in the seam, or if there's a structural problem. Is this something to be concerned about and how would I even go about fixing it?
Thanks so much
Old 05-01-18, 02:09 PM
Received 398 Votes on 354 Posts
Welcome to the forums!
Do you know if that is at a drywall joint? It almost looks like an issue with the tape.
I'd scrape off anything that is loose or higher than the surrounding drywall, then tape/mud and finish it like a drywall joint.
Old 05-01-18, 03:17 PM
Norm201's Avatar
Received 341 Votes on 307 Posts
The funny thing is that OP says it's bulging out ward. It's hard to tell from the pics but it does not look like the drywall joint was done wrong. And the pics don't show bulging. Perhaps if you lay a straight edge along the wall and took a pic we might better see what you have. Even a pic taken along the side of the wall.
The only thing that I would guess is that the 2 x 4 stud is not properly positioned or is slightly larger than it should be and the builder or modeler just didn't give a damn at that point.
Old 05-07-18, 02:22 PM
I don't know much about construction (we're new homeowners) but yes, I believe it is a drywall joint. And since noticing this bump, I've noticed a couple more that definitely weren't there when we moved in because I painted all the walls.
I'm just very, very worried that it might be a structural problem? The house was built in the 1950s so it shouldn't be settling at this point, right?
Old 05-07-18, 02:46 PM
That looks like failing tape to me. I'd cut out what is loose, retape and finish.
Old 05-07-18, 05:14 PM
Norm201's Avatar
I agree. ___________________________
