Has anyone seen this before.
Old 05-16-18, 09:03 PM
C
My neighbor below me has these persistent stains on her wall that she states occurs when it rains. However, the roof above her was fixed and when it rains these stains are completely dry which doesn’t make much sense. Has anyone seen stains like this before? It looks like the walls are crying or that there is moisture “bleeding” but again there is no obvious wetness or moisture. I’ve attached some images.
Old 05-16-18, 09:07 PM
XSleeper's Avatar
Received 1,844 Upvotes on 1,659 Posts
Looks like someone painted over old water stains that were not properly stain blocked with a primer.
Old 05-17-18, 03:58 AM
Received 800 Upvotes on 703 Posts
Is it just on exterior walls, every room or just a few select places?
I'd coat those areas with a solvent based primer then repaint.
Old 05-17-18, 05:35 AM
P
Received 2,009 Upvotes on 1,801 Posts
Water stains, tannins in wood and nicotine from cigarettes can all bleed through paint like that. As marksr mentioned an oil based stain blocking primer is needed to stop it. The important thing is to make absolutely certain that there is no leak. Sometimes water can soak through sheetrock just below the paint so even though there is water the surface may be dry.
